2002 Ford Taurus windshield wipers
130,000 MILES • 6 CYL • FWD • AUTOMATIC
KMBRLYJO
Wipers only worked in fast of slow position no intermittent function. When shut off they would stop wherever. Until they finally stopped completely.
replaced motor with no luck. Suspect swich or control module but have no idea how to check or even where the module is.
Dec 26, 2009 at 3:49 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check out the wiper relays first. you have 2, both located in the battery junction box (front center of engine compartment, behind radiator). should be labeled Wiper Hi/Lo Relay & Wiper Park/Run Relay.
Dec 26, 2009 at 7:05 AM
