2002 Ford Taurus Turn Signal and Hazard Flasher not working
PSGSTL
Electrical problem
2002 Ford Taurus
L/R turn signals and hazard flasher not working. Checked all fuses and relays under dash and engine compartment. All parking lights operate and brake lights. Installed new MFS which did not solve the problem. Since resolution of electrical issues are typically sequential, please bear this in mind when responding with recommendations.
Apr 28, 2010 at 8:00 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
You said you checked the relays, I just want to be certain you did test the actual flasher unit. If not, it is located behind the left hand side of the instrument panel at the left hand side of the steering column. It will be a square shaped relay and most likely grey or black. If you already tested this and it's good then you will need to test the wiring in the steering column to the hazard switch.
Apr 28, 2010 at 10:32 AM
PSGSTL
[quote:902085dbbf="bluelightnin6"]Hello and thanks for donating
You said you checked the relays, I just want to be certain you did test the actual flasher unit. If not, it is located behind the left hand side of the instrument panel at the left hand side of the steering column. It will be a square shaped relay and most likely grey or black. If you already tested this and it's good then you will need to test the wiring in the steering column to the hazard switch.[/quote:902085dbbf]
What connection points/terminals should be checked in the steering column female connector ? Which terminals should be hot: 1.with ignition off and 2. with ignition on?
Apr 29, 2010 at 12:18 AM
PSGSTL
[quote:2754d0c889="psgstl"][quote:2754d0c889="bluelightnin6"]Hello and thanks for donating
You said you checked the relays, I just want to be certain you did test the actual flasher unit. If not, it is located behind the left hand side of the instrument panel at the left hand side of the steering column. It will be a square shaped relay and most likely grey or black. If you already tested this and it's good then you will need to test the wiring in the steering column to the hazard switch.[/quote:2754d0c889]
What connection points/terminals should be checked in the steering column female connector ? Which terminals should be hot: 1.with ignition off and 2. with ignition on?[/quote:2754d0c889]
PS I can detect flasher relay clicking when depressing hazard on and off.
Apr 29, 2010 at 1:21 AM
BLUELIGHTNIN6
  • 16,542 POSTS
do the lights in the instrument cluster flash when the signals / hazards are turned on?
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2068.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_666.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname3_257.jpg
Apr 29, 2010 at 6:50 AM
