2002 Ford Taurus Transmission Support???
105,000 MILES • 6 CYL • FWD • AUTOMATIC
TANDC1990
Just got new tires for Taurus. Noticeable shake in steering wheel, especially when let off gas at about 60mph. Rebalanced tires, but still have problem. Tire mechanic drove car, & when he put it in gear, it hopped. Car had been doing this for a few weeks, & I had to really keep my foot on the brake hard when shifting. Popped hood & saw that engine was vibrating (actually shaking) when in drive. Mechanic said it is most likely a worn out transmission support, specifically the one on the driver's side at the back.
Does this sound right? The parts store has replacement assemblies for about $40 each. Is this something I could undertake with a "shade tree" mechanic? If so, any pointers would be appreciated.
Nov 4, 2008 at 4:02 AM
BMRFIXIT
  • 19,053 POSTS
should have it checked
also suspect axles and should have the checked too
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 4, 2008 at 12:46 PM
