2002 Ford Taurus transmission
86,124 MILES • 6 CYL • FWD • AUTOMATIC
SCULLINO
my ford taurus,sometime in low speed it jerks with out going progressive,i lift the foot from the axelleration and goes back normal.Also in reversing,it will have a kind of tremor,but going forward it is fine.
Do i have any problems?and what i need to do.The fluid is a little darker and not just bright pink,but i have not change it for a while,but the level has been always good
Feb 17, 2009 at 8:57 AM
  • 31,937 POSTS
HI there,
Thank you for the donation.
The darker fluid may be nothing more that normal discoloration due to age and normal component wear, i would get the transmission serviced by a trans specialist as they will be able to run a full diagnostic test on the transmission including pressure and shift settings and advise you if you have a problem or not, get this done next.
mark (mhpautos)
Feb 17, 2009 at 8:02 PM
