2002 Ford Taurus Temperature Switch
OLDTELETECH
Engine Cooling problem
2002 Ford Taurus 6 cyl Two Wheel Drive Automatic
Where is the temperature switch located
Sep 1, 2009 at 8:17 AM
BLUELIGHTNIN6
  • 16,542 POSTS
you mean temperature sensor..? if so, engine coolant temperature sensor is located on rear of engine block, near the thermostat. the engine coolant temperature sender is also located there.
Sep 1, 2009 at 8:25 AM
