2002 Ford Taurus Surging
106,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAN1965
Hey fellas thanks for the opportunity to ask my question. My Taurus intermittantly surges every 6-8 seconds. At stop lights I always drop it into nuetral so I don't have to bare down on my breaks. Their is also a cycling sound, that ends in a click, followed by the surge up to 1000 rpm when in nuetral. I can literally take my foot off the gas in low speed areas. I surge forward, coast and then surge forward. Any ideas? Thanks again.
Sep 27, 2009 at 5:05 PM
BMRFIXIT
  • 19,053 POSTS
Is the AC on or defrost
do you have check engine light on
checking for trouble codes would help
I would check for vacuum leaks
and specially around PCV valve
check and suspect IAC valve
Sep 28, 2009 at 9:59 AM
DAN1965
Thanks for getting back to my. There are no engine lights on. My AC hasn't worked in a while so is off. Also, I forgot to mention, there are occasionally small amounts of smoke coming from beneath the oil filter. I changed the oil and the filter but it didn't help.
Sep 28, 2009 at 11:48 AM
BMRFIXIT
  • 19,053 POSTS
Smoke is something leaking
have to check
make sure oil filter tight and check if switch around it leaking
Sep 28, 2009 at 12:21 PM
