2002 Ford Taurus STRUTS
66,180 MILES • 6 CYL • FWD • AUTOMATIC
DEC2650
GRINDING/SCRAPING SOUND HEARD WHEN DRIVING,HEARD A POP SOUND LIKE A BOLT SNAPPING. WHAT IS REPAIR COST?
Jan 13, 2008 at 4:23 AM
TAURUSWHEEL
  • 718 POSTS
need more info, way too general of a question, are you saying a strut broke?? Or you don't know??? A set of front struts, loaded type, probably set you back 450-500 installed, uneducated guess on my part as to the labor costs, struts gotta be around 175 each I'm guessing, loaded type ready to install.. the only way to go..
Jan 14, 2008 at 10:50 AM
ASANDBERG6
  • 25 POSTS
Struts aren't going to make a sound like that. Likely breaks metal to metal or wheel bearing. jack the front end up and shake tire holding at the top and bottom. remove whell and check brake linings. :|
Jan 14, 2008 at 11:12 AM
