2002 Ford Taurus Strange smell at start-up
NPADAMS19
Smells problem
2002 Ford Taurus 6 cyl 109000 miles
There is a strange smell when I start my car and the engine is cold...it smells like celery. It goes away after a couple minutes. Just a few notes: the defroster is on when I start it, with the heat turned all the way up. I also just had the coolant reservoir replaced and had a coolant system flush. I didn't have this smell before the repair.
Feb 24, 2009 at 11:37 AM
BLACKOP555
  • 10,386 POSTS
wheres i smell like celery? the exhaust?
could be coolant heating up and burning off. may be a leak somewhere, keep your eye on the colant level.
you got excessive white smoke?
Mar 8, 2009 at 2:00 PM
NPADAMS19
Thank you for the reply. I found out it was a leak in the water pump, and I was smelling coolant because it puddled up when the engine was cool.
Mar 9, 2009 at 4:06 AM
BLACKOP555
  • 10,386 POSTS
figured that it was coolant puddling up somewhere. glad to hear you were able to find it and fix it.
goodluck!
Mar 9, 2009 at 1:18 PM
