2002 Ford Taurus stalling
116,000 MILES • 6 CYL • FWD • AUTOMATIC
BART SWIHART
car gets warmed up and it wants to die when you stop when it dieshas to set a min before it will start. in park you can rev up the engine and it will die when the rpm's come down. found a vacuum leak fixed it.now its worse. also twice I have had a plug that would be soaked with gas. looked for more vac leaks have not found any.
Apr 26, 2009 at 10:27 AM
BMRFIXIT
  • 19,053 POSTS
is check engine light on ?
suspect idle air valve
check for any other vacuum leaks
Apr 27, 2009 at 2:32 PM
