2002 Ford Taurus shaft
172,000 MILES • 6 CYL • FWD • AUTOMATIC
PIE10045
I had a transmission rebuilt and when pulling off from a stop I hear a cluncking noise would this be something they did while repairing the transmission? When at a stop or pulling on to an exit ramp or up a hill my car fill as if it is going to die out it was not doing this until they rebulit my transmission. I was told that the clunking noise could be that they forced the shaft in to the transmission is this possible?
May 20, 2010 at 4:00 PM
BMRFIXIT
  • 19,053 POSTS
Should have it checked
check the CV axles
for the clonking
as for the almost stalling
open hood and check for vacuum leaks and check IAC valve remove and clean
May 20, 2010 at 11:30 PM
PIE10045
[quote:e599e003c7="BMRFIXIT"]Should have it checked
check the CV axles
for the clonking
open hood and check for vacuum leaks and check IAC valve remove and clean[/quote:e599e003c7]
May 21, 2010 at 12:26 AM
BMRFIXIT
  • 19,053 POSTS
click on reply to question (mid page)
type and then click submit
May 21, 2010 at 6:05 AM
