Wednesday, May 19th, 2010 AT 8:05 PM
I have a 2002 Ford Taurus V6 DOHC. When I start it it does not want to idle. I goes down low and jumps around. Even after I drive it when I come to a stop it does the same thing. Sometimes it will die. After 1000 RPM it is fine. Drives fine, accelerates fine. It has codes po171 and po174 lean bank 1 and 2. Also it has a pending code of p0113. Iat sensor 1 ckt high. Have read somewhere it could be a MAF. I don't want to spend the 100.00 if it could be something else. Any help would be appreciated.
