I have an 02 Ford Taurus SEL, After replacing the EGR Valve it still idles even more roughly than it had when it was bad. What else can it be?
Jun 19, 2009 at 1:37 PM
BMRFIXIT
✓Experienced Mechanic
Check for vacuum leaks
do you have check engine light on
do a code scan
let me know what you have for codes
coil is a common failure but you would get a misfiring code
check it out
good luck
