2002 Ford Taurus RMP/Surge
CSHUMAN13
2002 Ford Taurus
I read through related topics as best I could, but didn't see anything about intermittent revving. When I start my car, it idles excessively high, but then drops to normal for a matter of seconds before idling high again. If I put the car into Drive or Reverse, the car will jerk every time the engine revs high as if it's going to take off whether the break is on or not. My dad suggested that it may be a problem with the computer system. Initially, I wanted to know how much it would cost for the computer to be fixed, but now that I've read through your site, I'm wondering if it could be something else...maybe vacuum related. What do you think it could be? Is it something I can check (such as fuses or using a scanning tool to look for trouble codes)? What do you think it will cost to have it fixed?
Jul 24, 2010 at 10:10 PM
  • 75,988 POSTS
Try cleaning out the idle air control valve and also clean the MAF sensor with an approved cleaner and see what happens
Jul 24, 2010 at 10:25 PM
