Power steering pump flush
2002 FORD TAURUS
140,000 MILES • 6 CYL • FWD • AUTOMATIC
THIRDEYE1310
My car has made a whining noise since I bought it about six months ago. Since then I have replaced the power steering pump and reservoir and it still makes the same noise. I know it is in the steering because it does not steer as easy as it should and the noise gets louder when I turn the wheel. What could it be and how do I fix it? Thanks
Sep 26, 2010 at 5:24 AM
  • 110,241 POSTS
This is a very common problem. Based on what you have said, the fluid needs to be flushed out. Here is a guide to help you fix it;
https://www.2carpros.com/articles/power-steering-fluid-flush
Cheers
Jun 7, 2021 at 10:49 AM
BUICK BOI
Thank you. Worked perfect for my car!
