2002 Ford Taurus oil light flickers
179,000 MILES • 6 CYL • 2WD • AUTOMATIC
SIMPSON1197
02 tarurus runs fine then idles rough with engine noise and oil light flickers. this will last just a few secounds then goes away. had tune up did not change problem. thank you.
Jul 24, 2010 at 5:53 AM
BLUELIGHTNIN6
  • 16,542 POSTS
ensure engine oil is at proper level and is not burnt. if oil is good then oil pump may be weakening and needing replaced.
Jul 24, 2010 at 6:03 AM
