2002 Ford Taurus no heat
58,000 MILES • 6 CYL • FWD • AUTOMATIC
RICKYK110
coolant full, new thermostat,flow through heater core is good,manuel temp control.
get heat for about 5min. then cools down to no heat.
Oct 10, 2009 at 11:34 AM
BMRFIXIT
  • 19,053 POSTS
Recheck heater hose again and suspect heater core need to be flushed
and need to isolate heater core
try if possible to use some flush and let it sit in for few before running water through it
If engine overheating or running hot check water pump
Oct 10, 2009 at 12:46 PM
