2002 Ford Taurus lacks powder
SHEILA JACKSON
  • 7 POSTS
Transmission problem
2002 Ford Taurus Engine Size unknown Front Wheel Drive Automatic 125000 miles
whin I put the car in drive it start to drive then it slow down what could my problem be
Mar 15, 2008 at 7:14 AM
MERLIN2021
  • 17,250 POSTS
If the check engine light is on, the frst thing you need to do is have the codes read, Autozone does it free, Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored. If it's not on check your fuel pump pressure...
Mar 15, 2008 at 7:18 AM
