2002 Ford Taurus how much does it cost?
SEPHYA
Steering problem
2002 Ford Taurus 6 cyl Front Wheel Drive Automatic
How much does it cost to get the power steering checked and fixed?
The fluid has been refilled twice, when the car is running and I am moving the steering wheel there is a grinding noise and the steering fluid gets foamy and bubbly. I know there is a leak, I can see it.
and when the steering wheel is moving, there is smoke coming from the power steering "area" under the hood. One of the "metal parts" is shaking real bad where the belt is located.
So is this going to be a multiple fix or something simple?
Dec 27, 2008 at 10:25 AM
BMRFIXIT
  • 19,053 POSTS
Need to find the leak
you should have it checked
I would say under $50 to have it cleaned and checked and in some cases you may need to add dye to look for the leak
with out knowing what need to be replaced sorry I can’t give you a price
Dec 27, 2008 at 9:40 PM
