2002 Ford Taurus high idle
157,000 MILES • 6 CYL • FWD • AUTOMATIC
JEFRO3K
about three weeks ago the idle seems to be running higher, in gear and in park. It looks like the RPM is staying 200+ higher all the time. could it be the MAF or IAC? thanks
Mar 18, 2009 at 11:58 AM
BMRFIXIT
  • 19,053 POSTS
Do you have a check engine light on ?
check for a vacuum leaks
check the PCV valve and it hose check if hose collapsed and if so replace
check and clean IAC valve
if check engine light on scan for codes
and let me know
good luck
Mar 18, 2009 at 12:11 PM
