2002 Ford Taurus Hesitates
209,200 MILES • 6 CYL • FWD • AUTOMATIC
WILLISH68
a couple of days ago i drove through some high water and now the car will not go above 20mph. it happenend previously when i drove through an auto matic car wash. then went a way after i parked the car for a day. any ideas what could cause this. Thanks
May 20, 2010 at 9:30 AM
  • 75,988 POSTS
Hi willish68, welcome to 2carpros and Y for the donation
Disconnect the exhaust pipe temporarily and see what happens and get asap
May 20, 2010 at 9:37 AM
WILLISH68
I do not understand the ASAP part of your response." if i disconect the exhaust system"
May 21, 2010 at 8:07 AM
  • 75,988 POSTS
Water could have make it into the catalytic converter causing blockage-if you disconnect the exhaust pipe this will indicate if it improves in power-lets try this 1st as for the asap-to get back (as soon as possible)
May 21, 2010 at 9:30 AM
