A couple of days ago I drove through some high water and now the car will not go above 20mph. It happenend previously when I drove through an auto matic car wash. Then went a way after I parked the car for a day. Any ideas what could cause this. Thanks
SPONSORED LINKS
Thursday, May 20th, 2010 AT 4:30 PM
MECHANIC
Hi willish68, welcome to 2carpros and Y for the donation
Disconnect the exhaust pipe temporarily and see what happens and get asap
Thursday, May 20th, 2010 AT 4:37 PM
WILLISH68
MEMBER
I do not understand the ASAP part of your response." If I disconect the exhaust system"
SPONSORED LINKS
Friday, May 21st, 2010 AT 3:07 PM
MECHANIC
Water could have make it into the catalytic converter causing blockage-if you disconnect the exhaust pipe this will indicate if it improves in power-lets try this 1st as for the asap-to get back (as soon as possible)
