HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Taurus
Fuel System
Fuel leak
2002 Ford Taurus gas smell
DANCLAYT
MEMBER
2002 FORD TAURUS
6 CYL
FWD
AUTOMATIC
78,000 MILES
Can smell gas near filler pipe but do not see any leaks anywhere. Stronger smell when tank is topped off. Any ideas?
Friday, May 14th, 2010 AT 4:08 PM
BMRFIXIT
MECHANIC
Best way to check for leak is to have it smoke tested
where they use a smoke machine to add smoke to the system and look for leaks
you mush have a check engine light on with an EVAP codes !
SPONSORED LINKS
Wednesday, May 19th, 2010 AT 7:29 PM
Please
login
or
register
to post a reply.
Related Fuel Leak Content
What Is Causing The Raw Gas Smell Coming From The Car.
It May Be The Emission Control System That Has Gone Bad, But The Raw Gas Odor Is Strong. I Have Checked And Found No Leaks, So I Assume...
Asked by
rrcra
1 ANSWER
2002
FORD TAURUS
Leaking Gas
2002 Taurus Ses Dohc, Engine Hesitated, Lost Power And Gas Smell Coming Inside The Car. When I Made It Home I Noticed Gas On The Ground....
Asked by
didom3
1 ANSWER
2002
FORD TAURUS
1994 Ford Taurus Gas Smells
We Have Just Come Across A Gas Smell Coming From Our Car. We Can Smell Gas Coming Through The Vents When Running Ac And When Car Is Parked...
Asked by
leethsoccer
1 ANSWER
1994
FORD TAURUS
1997 Ford Taurus Gas Leak
Gas Leaks From Like The Top Of The Tank And Drips From Multiple Locations Constantly Until Only Approx. 1/32 Of Tank Left
Asked by
cmeyokovich
1997
FORD TAURUS
Gas Leaking Out Of Vapor Canister
Six Months Ago My 2001 Ford Taurus, 3.0l Dohc, 130k Mile, Fuel Tank Was Cleaned To Remove Charcoal Pellets Inside Tank, Replaced Fuel...
Asked by
llama
FORD TAURUS
VIEW MORE
Online car repair manuals
