2002 Ford Taurus engine pulses or shakes
73,450 MILES • 6 CYL • 2WD • AUTOMATIC
CARTEL2010
Recently the engine light is on for one month and my car starts to shake abruptly when I stump on the brake and the car is stopped. When I set the transmission at back and drivie position, the car shakes (or jumps)one more time. A mechanic changed the engine filters (maybe) on the top of the engine and cleaned them, skaking is reduced and the engine light is on again after 1 week driving. I can feel the brake pedal trembling very fast rigiht now. Can you please tell me what is going on?
Thanks a lot.
Mar 31, 2010 at 4:15 AM
BMRFIXIT
  • 19,053 POSTS
Check engine light on
1st step should be is to get the codes ,codes should indicate to what is going on
Check for vacuum leaks
Mar 31, 2010 at 11:20 PM
