2002 Ford Taurus ENGINE PROBLEM
182,000 MILES • 6 CYL • FWD • AUTOMATIC
GMATHIAS
I have a 2002 Taurus with the 24 valve engine; it has a couple of problems with the engine. During acceleration it stumbles and hesitates. During cruising it runs fine. It also has a high idle speed, it idles about 1400 rpm's. I have checked the codes and it stated it was the Idle Speed Control valve and also that cylinder six was missing.
Apr 22, 2009 at 3:03 AM
BMRFIXIT
  • 19,053 POSTS
Check idle air control valve common to fail
also may need a tune up and check coil if firing
if not replace coil
Apr 22, 2009 at 1:44 PM
