Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Taurus
Engine
Symptoms
Misfire
2002 Ford Taurus engine missfire
2002 FORD TAURUS
111,111 MILES • 6 CYL • 2WD • AUTOMATIC
JUSTINSWALLOW
MEMBER
1 POST
car is popping code is missfiring, read and cleared codes several times, comes up diffrent cly missfiring.
Jun 18, 2010 at 3:49 AM
Experienced Mechanic
Could be caused by the following
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Jun 18, 2010 at 9:44 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
