2002 Ford Taurus engine missfire
111,111 MILES • 6 CYL • 2WD • AUTOMATIC
JUSTINSWALLOW
car is popping code is missfiring, read and cleared codes several times, comes up diffrent cly missfiring.
Jun 18, 2010 at 3:49 AM
  • 75,988 POSTS
Could be caused by the following
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Jun 18, 2010 at 9:44 AM
