2002 Ford Taurus EATC
90,000 MILES • 6 CYL • FWD • AUTOMATIC
OTISP23
I have a Taurus with EATC. It will only blow heat when the temp is set at 90 degrees. I did the EATC diagnostic test and it came up 3 zeros (000). Also the outside thermometer registers at 129 even though its 20 degrees outside....THX.
Feb 20, 2010 at 12:41 AM
BMRFIXIT
  • 19,053 POSTS
The RCC module self-test will detect concerns in the system control functions and will display hard diagnostic trouble codes (DTCs) in addition to intermittent diagnostic trouble codes for concerns that occur during system operation. The vehicle interior temperature should be between 4 ° - 38 °C (40 °-100 °F) when carrying out the self-test. If the temperature is not within the specified range, false in-car temperature sensor DTCs will be displayed. use a scanner tool and check for B codes if possible
https://images.2carpros.com/forum/automotive_pictures/99387_7005_thumbnail_5.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_7005_thumbnail_4.jpg
Feb 21, 2010 at 10:16 AM
