2002 Ford Taurus coolant leak
160,000 MILES • 6 CYL • FWD • AUTOMATIC
DON.SHARON
My engine light came on so I immediately checked my oil and my engine coolant. The coolant resevior was nearly empty so I filled it with 50/50 coolant. The check engine light remains on and it seems that the coolant is not staying full, although it is not depleting quickly (I noticed a wet spot on my garage floor that looks like coolant). Is there a danger of harming my engine if I keep driving it while continuing to check and replenish the coolant until I can get it in to have it looked at? What does this sound like to you?
Oct 11, 2008 at 10:36 AM
2CARPRO JACK
  • 11,533 POSTS
The leak could be any number of things....too many to guess.If you monitor the coolant level and dont overheat the engine it should be ok for a few days til you have it looked at.The check engine light means that the computer that runs your engine/trans sees a problem. It will need to be scanned to find out what is wrong
Aug 21, 2020 at 6:29 AM
