2002 Ford Taurus comp. Problem
ROXIGIRL18
  • 2002 FORD TAURUS
2002 Ford Taurus
Was told my # 2 cyl. Only has 50% comp. And will need to be rebuilt. Was running rough prior to replacing plugs, wires and coil pak. But did not correct problem and had car looked at and was told a rebuild was needed or new engine. Car was running good and no knocks with great exceleration. Would this be a fact. Had car looked at because after running for about a few minutes it stopped and would not start but just turned over and popped a few times without starting. Any advice, thanks
Sunday, April 20th, 2008 AT 9:44 PM
  • 31,937 POSTS
Hi there,
I would like to know what the comp pressures are wet & dry you may have a burnt vales and don't need a few re build, see if you can get this test done, it is simple any work shop can do it.
Mark (mhpautos)
Monday, April 21st, 2008 AT 6:34 AM
