2002 Ford Taurus Check Enginge Light On Blinking
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
MSM1237
My cars check enging light came on and was solid and then periodically it would blink and when this happened it would want to stall. I took it to the mechanic and it was a misfire in cylinder 4. He cleaned the cylinder put fuel cleaner in it. It then happened again I took it back and the computer would not recognize the code. The mechanic then replaced all the plugs, air filter, cabin filter and wires. The light is again on and blinks and when I press the gas I cannot go. I then give it some gas and it eventually goes. It is back at the mechanic again but I would like to know what this problem is because I do not want to keep paying but still feel like I do not have a reliable car to drive.
Feb 21, 2010 at 9:40 AM
BMRFIXIT
  • 19,053 POSTS
Blinking check engine light is an indication of engine misfiring and shouldn’t drive on it when the light blinking
Have them check and suspect the coil
Feb 21, 2010 at 9:52 AM
