2002 Ford Taurus Check Engine Light....Again.
12,000 MILES • 6 CYL • FWD • AUTOMATIC
RON
This car has 120,000 freeway miles on it. Almost no problems at all except with the "check engine light" coming on, resetting itself, going off, coming back on, resetting itself. Car performs well and gets good mileage.
Thought it might be bad fuel and started running it on premium. That didn't stop the problem. It's time to change the fuel filter and pcv value....any chance this good be a factor?
Anyway, I'm not anxious to take it to the dealer given a past visit when said the engine was running a lean mixture and reset the light....no charge.
Your recommendation please.
Thanks.
Sep 25, 2008 at 10:25 AM
MERLIN2021
  • 17,250 POSTS
You do need to read the codes to get a handle on the problem, check out OBDII scanners, these will read your codes and then post them here.
Sep 26, 2008 at 7:37 AM
