2002 Ford Taurus car misses
108,000 MILES • 6 CYL • 2WD • AUTOMATIC
RAYSPENCE
The car starts and runs fine.After driving it for an hour or so it misses/stalls slightly on an incline.If i get off the gas and then accelerate it does fine.When I go through town and stop at a light you can feel the motor miss.
Oct 15, 2010 at 3:36 AM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Oct 15, 2010 at 4:21 PM
