2002 Ford Taurus A/C heater air flow is low
36,000 MILES • 6 CYL • FWD • AUTOMATIC
GLENN T
I replaced a defective blower motor and lost air flow. The blower motor has all 4 speeds, so I am assuming that the resistor is good. All of the blend doors seem to be working correctly, and the heat / cool door is working. I have tried 3 different blower motors with the same results. When turned to high speed, the blower motor it is like what low speed was on the original motor. What could the problem be?
Jun 2, 2010 at 5:53 AM
BLACKOP555
  • 10,386 POSTS
so all functions work as normal but high? and high is low speed?
Jun 3, 2010 at 5:08 AM
DABOMB1971
does the car have a cabin air filter? if so it may be clogged reducing air flow
Jun 4, 2010 at 9:07 AM
BLACKOP555
  • 10,386 POSTS
yes there vehicle does have a cabin airflow filter. and if they are looking for it they will find it on the passanger side of the vehicle after the upper cowl is removed by removing the 4 metal clamps holding it to the bottom cowel and the pulling up gently and popping out the several hold down clamps
Jun 4, 2010 at 11:31 AM
