2002 Ford Taurus AC Clutch Assembly
BACKOFPACK
Air Conditioning problem
2002 Ford Taurus 6 cyl Two Wheel Drive Automatic
Can you bypass the AC Clutch Assembly inorder to drive the car w/o air since the clutch is stuck?
Oct 7, 2009 at 12:23 PM
BMRFIXIT
  • 19,053 POSTS
Some you can and other you can not
very important is to keep the water pump spinning the same direction
check this page pick your
http://www.2carpros.com/car_repair_information/year/2002/make/ford/model/taurus/2002_ford_taurus_drive_belt_routing_diagram.htm
Oct 8, 2009 at 1:52 PM
