2002 Ford Taurus A/C Blower
134,000 MILES • 6 CYL • 2WD • AUTOMATIC
DODGER1AU
Our fan only works on Hi. I have replaced the resistor and this corrected the problem for a day. I have a replacement resistor but I don't want to install this one if the same problem is going to happen again. Is there a bigger problem that is causing the resistor to blow?
Aug 13, 2010 at 10:18 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check for a faulty blower motor relay, in the central junction box (under left side of dash)
Aug 13, 2010 at 10:23 AM
