2002 Ford Taurus abs and traction lights
30,000 MILES • 6 CYL • FWD • AUTOMATIC
TFISCH710
i have an 02 taurus. i put new front brake pads and had the roters cut about 8k miles ago. since then i have been experincing a shaking from the brakes {almost as if the roters were warped} the abs light and traction control off lights have been coming on and stayting on also. i inspected the roters and they seem fine.
Mar 14, 2009 at 4:53 AM
JGAROFALO
  • 489 POSTS
The brake shaking is probably coming from rotors that are out of parallel or otherwise not running true. The ABS and traction control problems may be a result of the brake work that was done.
At this point, I would suggest re-machining the rotors. They can be out of true or out of parallel and the problem will not be visible to visual inspection. While the brakes are apart, inspect the exciter wheel on the axle, and its relationship to the sensor. The exciter wheel is a toothed, round piece of metal that generates the pulses that the sensor reads to indicate the speed of that wheel. The end of the sensor should be close but not touching the exciter wheel. Next, check the wires leading from the sensor to the vehicle wiring harness. Connections should be clean and tight, with no spots rubbing or chafing on the body.
If everything checks out OK, you may have a bad sensor.
Mar 14, 2009 at 11:37 PM
