2002 Ford Taurus
KCANIGLIA
  • 2002 FORD TAURUS
  • 6 CYL
  • 116,000 MILES
My car is making a clicking noise mainly when going over bumps in the left side wheel changed the axle did not work they told me that the strut mount is broken does this sound right
Saturday, October 9th, 2010 AT 4:29 PM
  • 109,885 POSTS
Are they refering to the tower or the strut plate that bolts to it? I ask because if it is the tower, it is dangerous to drive. Strut plates (bearing) that bolts to the tower can go bad and will make the noise you described. The part isn't too expensive and is available aftermarket.
Let me know what they are telling you and the price so I can better direct you.
Saturday, October 9th, 2010 AT 10:35 PM
KCANIGLIA
I think they said the strut plate and told me I should replace the struts while I'm at it they said about $500
But I don't think the struts are bad is it hard to replace the mount myself
Sunday, October 10th, 2010 AT 1:45 PM
  • 109,885 POSTS
If the struts are good, keep them and only replace the plates. As far as replacement, the top strut mounts need removed. It isn't a bad job, but you need to be careful.
Monday, October 11th, 2010 AT 7:27 AM
