2001 Ford Taurus Wheel Bearing
135,000 MILES • 6 CYL • FWD • AUTOMATIC
GTSUM30181
A loud sqealing noise coming from right front side. From what i read its my bearings. When i looked and examine, my caliper looks like it is too close to rotor and i believe thats where the noise is coming from. But my wheel is slightly bent inwards whichs makes the caliper and rotor touch. Is this the most likely problem.??
Sep 20, 2010 at 9:54 AM
  • 110,248 POSTS
It sounds like you need new brakes. The brake pads have a steel sensor that touches the rotor when the pad wears out. Does the noise change when you use the brakes? If so, that is my first guess. A wheel bearing noise will go away when you make turns.
Also, how is the wheel bent?
Nov 10, 2017 at 4:28 AM
