2001 Ford Taurus Wheel Bearing
GTSUM30181
  • 2001 FORD TAURUS
  • 6 CYL
  • FWD
  • 135,000 MILES
A loud sqealing noise coming from right front side. From what I read its my bearings. When I looked and examine, my caliper looks like it is too close to rotor and I believe thats where the noise is coming from. But my wheel is slightly bent inwards whichs makes the caliper and rotor touch. Is this the most likely problem?
Monday, September 20th, 2010 AT 4:54 PM
  • 109,885 POSTS
It sounds like you need new brakes. The brake pads have a steel sensor that touches the rotor when the pad wears out. Does the noise change when you use the brakes? If so, that is my first guess. A wheel bearing noise will go away when you make turns.
Also, how is the wheel bent?
Friday, November 10th, 2017 AT 12:28 PM
