2001 Ford Taurus What is going on?
2001 FORD TAURUS
131,000 MILES • 6 CYL • FWD • AUTOMATIC
MRSMCDANIEL
we were driving down the road and all the sudden it wouldn't go anymore the motor was running fine it acted like the transmission went out then we pulled the battery cable off and the car died when we put it back on it started with no problems but it will not go anywhere. we let the car run for 30 to 45 min. and the battery is still good so it's can't be the alt. we are at a loss and can't think of anything eles that it could be we have checked all fuses ad none of them are blown we even let the car sit for an hour with the battery cable off and put it on and it is still doing the same thing Thanks so much for your help
Oct 4, 2009 at 11:04 PM
BMRFIXIT
  • 19,053 POSTS
Check tranny fluid and also check axles
if all checked OK suspect internal tranny failure
tranny need to be replaced and or rebuilt
Oct 5, 2009 at 5:39 PM
