2001 Ford Taurus water pump
13,000 MILES • 4 CYL • FWD • AUTOMATIC
SHAR LITTLE
Could having an engine flushed cause the water pump to leak and need replacing? A few weeks ago I went to a chain oil change place and because I went 6,000 miles between oil changes the mechanic suggested I have an engine flush which I agreed to. The car remained parked for the day after the flush/change. That evening I noticed about 3 tablespoons of fluid on the front passenger side about a foot in from the tire. I called the chain store which said it could be drips from spilling. The drips continued so I took it back and the mechanic said that I need a new water pump. How long can a leaky water pump last if I keep antifreeze filled? (no noticable level decreases yet)
Jan 23, 2008 at 9:46 AM
BMRFIXIT
  • 19,053 POSTS
[quote:40370ca768="shar little"]Other Category problem
2001 Ford Taurus 4 cyl Front Wheel Drive Automatic 130,00 miles
Could having an engine flushed cause the water pump to leak and need replacing? A few weeks ago I went to a chain oil change place and because I went 6,000 miles between oil changes the mechanic suggested I have an engine flush which I agreed to. The car remained parked for the day after the flush/change. That evening I noticed about 3 tablespoons of fluid on the front passenger side about a foot in from the tire. I called the chain store which said it could be drips from spilling. The drips continued so I took it back and the mechanic said that I need a new water pump. How long can a leaky water pump last if I keep antifreeze filled? (no noticable level decreases yet)[/quote:40370ca768]
there is no time limits on that
and you cant say it will last a day or a year
if you do a long trips you should have it replace ASAP
keep coolant full
if you hear a noise from the pump change it time is up
Jan 23, 2008 at 10:04 AM
