Engine Cooling problem
2001 Ford Taurus 6 cyl Front Wheel Drive 10100 miles
water is leaking from the coolant tank, is not running hot and tank was replaced last year, however the water in the tank is bubbling hot at times, have to put water in it daily and with winter coming up it is going to freeze cause anti freeze will leak out of it. Was wondering if it could be the thermostat, pressure cap on tank or water pump or what?
Sep 24, 2010 at 4:49 PM
