2001 Ford Taurus vaccume leak? And tune up
TXTURTLELYTIGER
  • 2001 FORD TAURUS
Engine Performance problem
2001 Ford Taurus Automatic
im due for a tune up next week and I already had all the oil stuff done and the fuel filter replaced. I was wondering if anybody can give me a list of all of the 2001 ford taurus sensors. And I think my car has a vaccume leak? It acts like it age or older, rough idleling, doesnt like going up hill, sputters, has a problem with accelerating like it is working harder to get up-speed and I have to sometimes press down on the acceleration a bunch of times to get it to speed, and it sometimes messes up on the throttle with unexpected burts of speed sometimes when or after starting/moving the taurus. Im not sure if its the throttle or engine knock? Thx
Saturday, July 10th, 2010 AT 10:49 PM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking, fuel filter or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Sunday, July 11th, 2010 AT 2:12 AM
