Type of SparkPlugs: AWSF-32FM
REMOVAL
Remove the coil per plug unit.
Loosen spark plugs a 1/4 turn, and using compressed air, remove any dirt or foreign material from spark plug areas of cylinder heads.
Remove spark plugs.
Inspect and, if necessary, replace spark plugs.
INSTALLATION
Follow removal procedure in reverse order.
Tighten spark plugs to 9-20 Nm (7-15 lb ft).
Sunday, October 17th, 2010 AT 1:11 AM
