2001 Ford Taurus trouble codes
246,000 MILES • 6 CYL • FWD • AUTOMATIC
TRAINWRECKER74
i read the trouble codes for the car. there were two, bank one and bank two lean fuel. how do i know which is bank one and which is bank two also i am replacing o2 sensors is this likely the problem, but there are four is it telling me to replace the upstream sensors the downstream sensors the rear front and back or what? please help thanks. trainwrecker74
Feb 6, 2009 at 7:27 AM
BMRFIXIT
  • 19,053 POSTS
Check PCV valve and vacuum lines
lean codes is a vacuum leaks and or MAF sensor
Feb 6, 2009 at 1:49 PM
