2001 Ford Taurus Transmission Fluid Leak
64,000 MILES • 6 CYL • 2WD • AUTOMATIC
AB_SOOD
  • 8 POSTS
I see is few drops of ATF, dropping over the exhaust pipe, picture below. Its about a quart a month.
It doesn't look like the pan gasket leaking.
What should be leaking from tranny above the exhaust pipe ?
Should this be the Axle seal or the front pump seal ?
Whats above the Exhaust pipe.. Axle seal or Pump seal ?
Kindly help.
Abi
Mar 14, 2009 at 7:21 PM
  • 31,937 POSTS
Hi there.
You should be able to wash the trans down and check for the fresh leak after a drive, it could be the pan gasket as the slip stream can carry oil back as you drive.
Mark (mhpautos)
Mar 14, 2009 at 7:39 PM
