2001 Ford Taurus Trans overheats
73,182 MILES • 6 CYL • FWD • AUTOMATIC
LIL58
My transmission overheated and blew the fluid out the front 235 miles into a trip. The Torque converter had been replaced recently. What could cause the overheating problem? It ran and operated perfect until this happened.
Apr 25, 2009 at 2:07 AM
JGAROFALO
  • 489 POSTS
[quote:0b08554c2d="Lil58"]Transmission problem
2001 Ford Taurus 6 cyl Front Wheel Drive Automatic 73,182 miles
My transmission overheated and blew the fluid out the front 235 miles into a trip. The Torque converter had been replaced recently. What could cause the overheating problem? It ran and operated perfect until this happened.[/quote:0b08554c2d]
Possibly the vent became plugged. Are you sure that the transmission actually overheated? Or did it just push the fluid out?
Have the system checked for codes. If the transmission did in fact overheat, there will be a related trouble code in the system.
FYI - even overheating will not cause the fluid to come out. You would have to reach a VERY HIGH temperature to boil the transmission oil, and the transmission would have burned out long before that happened.
Apr 26, 2009 at 1:29 AM
