2001 Ford Taurus starting problem
16,600 MILES • 6 CYL • 2WD • AUTOMATIC
DONP77
My car will usually start after it has been sitting for a little bit but if i turn it off and try to restart it again it doesn't always start. I had the battery checked and it was fine. Some days it gives me no problems. Could it be the starter?
Jun 6, 2008 at 6:31 AM
  • 75,988 POSTS
If its cranking over and refusing to start the starter is doing its job.
If the engine's condition is in tip top shape-do below to determine if its fuel or spark problem that's if its cranking over and refuses to start
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Jun 6, 2008 at 8:08 AM
