2001 Ford Taurus Stalls/Rough Idle
228,000 MILES • 6 CYL • FWD • AUTOMATIC
BIGOUNCE
I have replaced spark plugs and wires as well as coil and EGR press feed sensor. I have had fuel filter replace and fuel system flushed. Car still starts rough at times and will occasionally stall when braking. I notice this happens the most in wet weather or when it has rained during the night
Jun 23, 2008 at 9:21 AM
  • 75,988 POSTS
Inspect and test the engine coolant temperature sensor/idle speed control motor/valve and throttle position sensor-
Jun 23, 2008 at 9:37 AM
