2001 Ford Taurus Stalls
12,600 MILES • 6 CYL • FWD • AUTOMATIC
MOZIPS83
My car stalls at stoplights. it idles very low when its in drive, and if I'm stopped for a few minutes, its dies. the dealership I purchased it from said that they replaced the 02 sensors when the engine light came on, but after replacing them, the light came back on. is it the sensors that are causing this, or something else?
Feb 15, 2010 at 12:40 PM
BMRFIXIT
  • 19,053 POSTS
Have check engine light on need to get the codes
Check for vacuum leaks
Check IAC valve (remove and clean)
Check MAF sensor (remove and clean)
Feb 16, 2010 at 10:57 AM
